Comsol Capacity Fade model C-Factor influence
Posted 1 mar 2016, 04:50 GMT-5 0 Replies
I have the following question. There is a capacity fade model in comsol examples. I used it. And it is simulating ok. Then I wanted to change the C-factor without changing 1C value. The thing is that it didn't influence anyting. Results were the same. There is a parameter for C-Factor = "a". And it influences the i_load parameter. I checked the model and there is no place where it was used.
So what I did was just simulating the battery on 1C. (when cfactor is 1)
The task is to simulate the battery at different c-factors. Even though the model contains that paraemters they are not used. Could you please help how to make it work with c factor?
Hello Yerzhan Massalin
