22 ott 2010, 05:58 GMT-4
well
I dont have an answer for your specific problem but it MIGHT have to do with the parametric solver itself
reason I think that is that I am currently experiencing the following problem
I have a complicated stationary problem multiphysics fully coupled
I want to vary One parameter...
if i ran the parameters one by one putting then by hand in the stationnary model [ and changing nothing else of course} all thecase converge and the solution is correct..
If I ran a matlab loop to vary the parameters ..... I get all my solutions again....
BUT if I want to use comsol parametric solver [ which I used often] it provides me with the first solution but then fail to find the other ones because of convergence issue!!
So, It seems that comsol parametric solver try to be ¨smart" on its one and i am currently struggling to find a way to force him to be stupid...
you might face the same problem where it adjust some default value on its own depending on what you tell him to do;;;
well, shared misery is still misery...
butbased on my experience, I will suggest to build a matlab loop instead of using the builtin parametric solver.
You can control your distribution on cluster node as you wish AND make sure the solver settings are not changed behind your back.... which I suspect is what is happening in my case.. still working on it
for whatever its worth....
JF
well
JF
22 ott 2010, 06:12 GMT-4
your reply is exellent. I also maintain that using the matlab loop instead of the bulit-in parametric sweep.
but also have some question about the matlab loop
when I sweep for a large times, the matlab crashed, returning java.lang.OutOfMemoryError: Java heap space, even i change the java heap size.
Did you guys encounter the same question. if you have, how did you figure it out?
22 ott 2010, 08:41 GMT-4
Well, actually my first model was not using parametric sweep (I planned to do the parametric study this week end). The problem appear on a simple time dependent problem...
But thank you for the hint, it will help me to save time.
16 apr 2011, 07:13 GMT-4
I'm suffering the same problem now. When i do a parametric sweep ,only the first several values will lead to solutions,and then the solver will stop to warn " Error in sweep: Java heap space".
Have you resolved your problem or how did you make it? If i want to use loop in matlab replacing the built-in parametric sweep, what should i do?
Best regards
Yulong Yang
[QUOTE]
[/QUOTE]
Best regards
Yulong Yang
17 apr 2011, 01:37 GMT-4
well
JF
Best regards
Yulong Yang
[QUOTE]
well
JF
[/QUOTE]
Best regards
Yulong Yang
