Hello Ahmad Zubair
27 gen 2011, 05:53 CET
Have you got any answer for this problem? I am also looking the same
27 gen 2011, 07:16 CET
first of all you should specify the version you are using, that would stimulate the right people here on the Forum.
Then, why not try it out and see in the COMSOL GUI environment what you get ?
27 gen 2011, 10:41 CET
No, I'm still in the same problem
27 gen 2011, 11:03 CET
I need to built a model that can be used for structures with different number of subdomains based on the users demand. Is there any way to do it using GUI?
25 mar 2011, 16:28 CET
I stere a solution to this Problem availible?
28 mar 2011, 10:45 CEST
Hello, I am new to this forum and I see a lot of topics open like this. Is there an active community or is this dead?
I also try to build a geometry using a loop:
for i=1:L
g{i}=rect2(0.8,width*i,'base','corner','pos',[0,width*(i-1)]);
s.objs={g1(i)};
s.name{i}='R' & num2str(i);
s.tags{i}= 'g' & num2str(i);
end
but it appears not to work out. Is there a solution for this? If one has a solution could he/she post the correct syntax (not like this
www.comsol.com/community/forums/general/thread/6131/ )
for i=1:L
s.objs={g1(i)};
end
but it appears not to work out. Is there a solution for this? If one has a solution could he/she post the correct syntax (not like this http://www.comsol.com/community/forums/general/thread/6131/ )
