Wavefront simulation
Hello all,
I'm quite new to COMSOL and I'm trying to simulate the effect of curved surface (which I change using the structural mechanics module) on the reflection of a plane wave.
I can't find a way to plot the wavefront of the EM wave reflected from the curved surface.
Can anyone help me with that or give me a hint?
Thank you,
Andrey
2 Replies Last Post 13 mar 2016, 03:13 GMT-4
Posted: 9 years ago 10 mar 2016, 12:38 GMT-5
in the EM study, you can use scattered field formulation. By defining a background field, for example, a plane wave in travelling in the -y direction, Ez=exp(j*k0*y), you can obtain the scattered field, which is your reflected wave.
Posted: 9 years ago 13 mar 2016, 03:13 GMT-4
Ok, Thank you.
Do you know if I can select any volume and plot a 3D surface inside this volume under some condition (e.g same phase)?
Thank you,
Andrey
Ok, Thank you. Do you know if I can select any volume and plot a 3D surface inside this volume under some condition (e.g same phase)? Thank you, Andrey
