unknown unit error in COMSOL4.0
Posted 30 nov 2010, 22:23 GMT-5 1 Reply
hi, everyone!
I am a COMSOL4.0 beginner. I simulated a simple 2D-piezoelectric SAW modal. It 's a reatangle in attachment file. Its boundary conditions consisted periodic boundary on two sides and fixed constraint on bottom. When I used m, cm, mm units system, it could work , only many warnings, 'The relative residual is greater than the relative tolerance. Relative residual 8.5e-014 Relative error 1e+002' . However, when i used um unit system, a error occured, 'Unknown unit - Unit: ?m'.
Locate the Geometry Settings section. Find the Units subsection. From the Length unit list, select µm
Thanks for consideration, any help is appreciated.
1 Reply Last Post 1 dic 2010, 03:04 GMT-5
