Accessing results while solving problem
I have a transient problem where I implemented a scalar variable f(t). Since f(t) is dependent on f(t-1), I need to access the result during solution. How can I access this variable during the solution process?
Thanks in advance
Best
Ivan
1 Reply Last Post 2 dic 2010, 01:21 GMT-5
Posted: 1 decade ago 2 dic 2010, 01:21 GMT-5
check the Forum (tra a serch) there are several discussion on accessing (or npt) last timesteps, you have also the at() and with() operators, but I sue them in the postprocessing. I believe there is even more on the knowledgebase of COMSOL, try a search there too
Hi check the Forum (tra a serch) there are several discussion on accessing (or npt) last timesteps, you have also the at() and with() operators, but I sue them in the postprocessing. I believe there is even more on the knowledgebase of COMSOL, try a search there too -- Good luck Ivar
