Assigning Different Material without Changing Mesh
Hello everyone;
I want to assign a material for a very small domain within a large domain without changing the meshing. For instance let's say you have a very big solid cube of aluminum and you want a smaller golden cube within the bigger cube. To do that, I draw the cubes within each other, but meshing gets very intense on the regions where these two cubes intersect. I don't want that. I want a homogenous meshing across all domains. How can I do that? Any help is appreciated.
Best
mehmet
1 Reply Last Post 22 lug 2016, 10:55 GMT-4
Posted: 8 years ago 22 lug 2016, 10:55 GMT-4
You can do it by giving the material properties as function of spatial dimensions. You can use logical operators to specify material properties such if(sqrt((x-xo)^2+(y-yo)^2)< r_particle, Mat_p, Mat_d) where, the xo, yo are the origin of particle of radius 'particle.
However, a sharp change in material properties can make solver convergence difficult.
You can do it by giving the material properties as function of spatial dimensions. You can use logical operators to specify material properties such if(sqrt((x-xo)^2+(y-yo)^2)< r_particle, Mat_p, Mat_d) where, the xo, yo are the origin of particle of radius 'particle. However, a sharp change in material properties can make solver convergence difficult.
