Structural module, thin elastic layer with nonlinear forces, solver option for nonlinear systems
Hi everyone!
I'm modeling a quite simple system of a composite material. Basically three cylindrical fibers embedded in a cuboid matrix.
All the materials are linear elastic. The numerical simulation aims to reproduce a quasi-static test so I use a parametric sweep over the imposed displacement with a relative small loading step.
Particularly I model the matrix/fiber interfaces, i.e., the external surface of the cylinders, as a thin elastic layer (TEL) with a nonlinear force of the type:
F= C [u]^3
in which C is a stiffness constant (the same for all three matrix/fiber interfaces) and [u] is the displacement jump.
Questions:
- Can I use a single TEL for all fibers? Or I must create a TEL for every cylinder?
- Using the TEL option on a cylindrical surface require some particular attentions?
- Finally, because of this modeling choice concerning interfaces I have to solve a nonlinear and implicit system of equations, moreover the interface stiffnesses are very high, as a result I have some convergence problems.
What is, in my case, the optimal choice for the solver configuration?
Thank you in advance.
0 Replies Last Post 28 lug 2016, 07:26 GMT-4
Hello Maria Letizia Raffa
