16 dic 2010, 10:12 GMT-5
the "from model (ht/fluid1)" is simply the "T" value of the other physics (you have probably 2 physics including a Heat transfer in Fluids (ht/fluid1). This is the one to select if you couple the physics. But if you want to decide which temperature you use in your specific physics you can define it as a "user input".
A user input of fluid1.ht.T (or T2, T3... depending on its internal naming) is the same as the "from model" case
16 dic 2010, 11:16 GMT-5
great thanks,
the only thing i dont understand is why for short times my model doesnt solve when i use temperature input from ht? but solved fine when i put in a user defined variable.
J
great thanks,
J
16 dic 2010, 13:25 GMT-5
well have you plotted the ht.T temperature to check that it is changing with time?,
and check how the solvers are linked, if you solve all variabls (or if ht is not selected it will not solve at all and the link will be wrong), or if you solve them as a segregated set, which oones are first second, is this the right order. COMSOL makes som guesses, bu sometimes it's wrong w.r.t. your specific model.
16 dic 2010, 13:42 GMT-5
thanks again i really appreciate your help,
i dont think its one of what you recommended: the temperature is changing, and the model is solving for both physics (fully coupeled).
what is bothering me is that after 0.001 sec the result looks great, but for 0.0001 sec the result is complete noise (looks like numerical instability).
what do you think doc?
16 dic 2010, 13:45 GMT-5
mostly temperature effects are reevant in the order of seconds or minutes, OK if you are working with MEMS its faster, or liquid metal quenching.
17 dic 2010, 04:26 GMT-5
ha great,
I dont think its that, but it works now (after some changes to the solver). many many thanks,
J
ha great,
J
17 dic 2010, 04:27 GMT-5
PS. Ivan you rock! we all appreciate your help!
