Transient and stationary case together
in coupled multimodes, is it possible to work transient and stationary cases together, ie. some of modules are in transient while the other/others in stationary. By the way, stationary module solution depends on the transient results and vice versa.
1 Reply Last Post 31 dic 2010, 01:07 GMT-5
Posted: 1 decade ago 31 dic 2010, 01:07 GMT-5
you need to set up multiple solvers, in the right order, and possibly adapt the solver sequence manually (typically by using segregated steps) these manual tunings can only be done by a human, as COMSOL cannot guess (yet?) all combinations of complex multiphyiscs cases
This is working far easier and better in v4.1 than in the first v4.0 version (and w.r.t. 3.5a too) so get hand on latest version
Hi you need to set up multiple solvers, in the right order, and possibly adapt the solver sequence manually (typically by using segregated steps) these manual tunings can only be done by a human, as COMSOL cannot guess (yet?) all combinations of complex multiphyiscs cases This is working far easier and better in v4.1 than in the first v4.0 version (and w.r.t. 3.5a too) so get hand on latest version -- Good luck Ivar
