How to store parametric sweep results in single file or MATLAB variable
Posted 3 gen 2011, 14:32 GMT-5 LiveLink for MATLAB, Results & Visualization Version 4.0a 3 Replies
Hello
I need to perform several nested parametric sweeps in order to vary several geometric parameters simultaneously (I'm using Comsol version 4.0a)
If I add a "Report to file" task in the inner parametric sweep, in order to export the value, say, of a line integration along one boundary, COMSOL generates one text file per parameters set.
This is very unconfortable in my case in which I have several thousand of parameter sets.
Do anyone know a way to export the calculated quantities in a single text file?
I cannot store the solution for every parameter set in the model and perform the calculation of the derived quantities after solving, since the whole mph file would be become too large.
I tried to work with the .m file and Comsol + matlab livelink but I still couldn't get rid of this problem. The code automatically generated by Comsol contains the following lines
model.batch.create('p1', 'Parametric');
model.batch('p1').feature.create('so1', 'Solutionseq');
model.batch('p1').feature.create('nu1', 'Numericalseq');
but I can't understand how to access the calculated quantities in the numerical sequence.
Thanks for reading
best regards,
Pierfrancesco
Thanks for reading
best regards,
Pierfrancesco
3 Replies Last Post 24 nov 2011, 10:39 GMT-5
