Passing Parameters into geometry features via MATLAB LiveLink
Posted 21 gen 2011, 14:43 GMT-5 Interfacing, Geometry Version 4.1 0 Replies
I've attached the .m file, and here are the lines in question...
model.param.set('ridge.r', 1);
%creating a square and other geometry works fine
model.geom('geom1').feature('wp1').geom.feature.create('s1', 'Square');
model.geom('geom1').feature('wp1').geom.feature('s1').set('base', 'center');
model.geom('geom1').feature('wp1').geom.feature('s1').set('size', 'ridge.r');
%'ridge.r' is passed into the model.
model.geom('geom1').feature('wp1').geom.feature('s1').set('pos', {'ridge.t/2-ridge.r/2' 'ridge.w/2-ridge.r/2'});
%creating an extrusion does not work the same way
model.geom('geom1').feature.create('ext1', 'Extrude');
model.geom('geom1').feature('ext1').selection('input').set({'wp1.r1'});
model.geom('geom1').feature('ext1').set('crossfaces', 'off');
model.geom('geom1').feature('ext1').set('distance', 'ridge.r');
%'ridge.r' is not passed into the model. The value 1 is passed into the model.
Any thoughts?
Hello David Hodgson
