coil impedance
Hi every body,
I am a new user of COMSOL and I started to do a simulation of a nondestructive testing problem. My model is composed of a circular multiturn coil above a metal plate. an alternative current is applied to the coil, and I want to calculate the impedance of the coil.
please can anyone help me to solve my problem ?
3 Replies Last Post 26 gen 2017, 09:37 GMT-5
Dave Greve Certified Consultant
Posted: 7 years ago 24 gen 2017, 12:47 GMT-5
If I am understanding you correctly- you should look in the application library for "coil above plate." In that example you can perform a Global Evaluation (under Derived Values) using the expression mf.ZCoil_1 (1 being the coil number) found under Coil Parameters.
This gives you the complex coil impedance.
DW Greve
DWGreve Consulting
If I am understanding you correctly- you should look in the application library for "coil above plate." In that example you can perform a Global Evaluation (under Derived Values) using the expression mf.ZCoil_1 (1 being the coil number) found under Coil Parameters. This gives you the complex coil impedance. DW Greve DWGreve Consulting
Posted: 7 years ago 25 gen 2017, 05:19 GMT-5
Thank you very much for your response, actually I already did what you said to me and I have got the impedance but when I look at the values I think that there is something wrong. may be I didn't set the poblem correctly.
1/Is there a difference in results if we use a circular multiturn coil or numeric multiturn coil?
2/ can I send you what I did to look at it when you have time?
Thank you very much for your response, actually I already did what you said to me and I have got the impedance but when I look at the values I think that there is something wrong. may be I didn't set the poblem correctly. 1/Is there a difference in results if we use a circular multiturn coil or numeric multiturn coil? 2/ can I send you what I did to look at it when you have time?
Nirmal Paudel Tribhuvan University/Electrical Engineering
Posted: 7 years ago 26 gen 2017, 09:37 GMT-5
Hi Bouhlal,
The following Application Example include a collection of different types of coils in 3D, which I think is very useful for understanding the difference in the result.
www.comsol.com/model/3d-coil-types-in-comsol-multiphysics-42431
Best Regards,
Nirmal
Hi Bouhlal, The following Application Example include a collection of different types of coils in 3D, which I think is very useful for understanding the difference in the result. https://www.comsol.com/model/3d-coil-types-in-comsol-multiphysics-42431 Best Regards, Nirmal
