Comsol 4.1 plotting error message: "mphplot at 154"
Hello, my name is Kristian Ejlebjerg Jensen and I am able to use Comsol 4.1 and its sensitivity analysis for topology optimization with an external optimization algorithm (MMA).
My problem relates to plotting of the actual design field (the optimization runs fine, when I plot the solution variables). I have attached an example script. After the design field is updated (using the setU and createSolution functions), I try to visualize this new design field. I however get the following error
??? Subscript indices must either be real positive integers or logicals.
Error in ==> C:\programs\COMSOL41\mli\mphplot.p>l_color at 1489
Error in ==> C:\programs\COMSOL41\mli\mphplot.p>l_computecolor at 1453
Error in ==> C:\programs\COMSOL41\mli\mphplot.p>addplot at 250
Error in ==> C:\programs\COMSOL41\mli\mphplot.p>mphplot at 154
(I am not sure as to the application of the "server" option for mphplot, but I just get a blank figure, when I try to use it.)
5 Replies Last Post 15 apr 2011, 02:03 GMT-4
Posted: 1 decade ago 28 gen 2011, 08:43 GMT-5
The problem is NOT solved with the recent update.
Posted: 1 decade ago 4 feb 2011, 05:17 GMT-5
I just got word that this is a bug to be fixed in Comsol 4.2.
Posted: 1 decade ago 18 feb 2011, 02:27 GMT-5
I have the same problem, is there no solution/work around yet?
Posted: 1 decade ago 16 mar 2011, 22:27 GMT-4
To resolve the issue in Matlab - COMSOL 4.1, you might want to try the following.
1. Define a full density field for both the design domain and the non-design domain. You could set the density value for the non-design domain however you see fit.
2. Visualize this full density field.
To resolve the issue in Matlab - COMSOL 4.1, you might want to try the following. 1. Define a full density field for both the design domain and the non-design domain. You could set the density value for the non-design domain however you see fit. 2. Visualize this full density field.
Posted: 1 decade ago 15 apr 2011, 02:03 GMT-4
Hi Kristian,
I am working on applying topology optimization in fuel cells. However, I am facing difficulty in coding in MATLAB. I have two problems:
1. How to compute the volume below the design variable basis function (gamma)?
2. How to extract the objective sensitivity with respect to gamma from the same location where gamma is specified?
Can you please shed light on these two problems.
Praveen
Hi Kristian, I am working on applying topology optimization in fuel cells. However, I am facing difficulty in coding in MATLAB. I have two problems: 1. How to compute the volume below the design variable basis function (gamma)? 2. How to extract the objective sensitivity with respect to gamma from the same location where gamma is specified? Can you please shed light on these two problems. Regards, Praveen
