Remeshing the geometry
Is there any way to tell the software not to store all of the remeshed solutions? Or store every nth solution?
In my simulation, the geometry needs to be remeshed many times to fulfill the remeshing condition. This makes the file huge.
Amin,
1 Reply Last Post 1 mag 2017, 03:02 GMT-4
Posted: 8 years ago 1 mag 2017, 03:02 GMT-4
Updated: 8 years ago 1 mag 2017, 03:03 GMT-4
It sounds like your simulation consists of many steps that takes the remeshed geometry from one step's solution and uses it in the next and repeats? I think that if you only need the most recent remesh, a good way to go might be to use the application builder and write in a code that clears the remeshed geometry on each iteration. A good starting point for that is here: www.comsol.com/blogs/automate-model-preprocessing-with-the-application-builder/
Hopefully that can help.
Nick
It sounds like your simulation consists of many steps that takes the remeshed geometry from one step's solution and uses it in the next and repeats? I think that if you only need the most recent remesh, a good way to go might be to use the application builder and write in a code that clears the remeshed geometry on each iteration. A good starting point for that is here: https://www.comsol.com/blogs/automate-model-preprocessing-with-the-application-builder/ Hopefully that can help. -- Nick
