Mass conservation
Posted 9 mag 2017, 16:35 GMT-4 2 Replies
have a 2D fluid flow model with a flow through porous media. There is one inlet with 20 mm/s inlet velocity and I assume conservation of mass.
I want to check that the numerical mass balance of the models close with a reasonable error. To estimate if the result is reliable and not create or destroy water numerically in the calculation process.
Considering what the blog says in www.comsol.com/blogs/how-to-calculate-mass-conservation-and-energy-balance/. I went to Results > Derived Values > Integration > Line Integration
The expression you use is written as: spf.rho*(vi).
Where spf.rho is the density of the fluid and vi is the velocity.
Can someone confirm that this is the correct way to calculate mass conservation in 2D models?
2 Replies Last Post 15 mag 2017, 17:03 GMT-4
