How to couple turbulent flow and porous flow?
Hi, I want to calculate the compressible & turbulent flow and heat transfer in porous media. Here I have two questions.
1. How to couple the turbulent flow and porous flow?
2. I want to consider the fluid's pressure work and viscous heating, however I can not find the options in the model of porous heat transfer. What should I do?
Thank you very much.
1 Reply Last Post 4 set 2013, 10:20 GMT-4
Hello Dongzhi Guo
Posted: 1 decade ago 4 set 2013, 10:20 GMT-4
I am also very interested in this topic:
Have you found any solution?
I am also very interested in this topic: How to couple the turbulent flow and porous flow? Have you found any solution?
