Modeling a Kerr Effect
Hello.
I want to model a material with birefringence that depends on the electric field inside the medium, similar to the Kerr effect where the index depends on the square of the field. This is complicated by the fact that:
1. The field is not uniform.
2. The index dependence on the field is slightly different than a power of 2 (perhaps 1.5).
3. There is an added continuous spatial modulation to the birefringence.
How can this can be done? I suspect the easiest way to just throw the electric field into the differential equations. Is that possible and how can I do that?
Thank you.
2 Replies Last Post 23 mag 2013, 11:50 GMT-4
Hello cchriste
Posted: 1 decade ago 22 mag 2013, 09:38 GMT-4
Dear cchriste
did you solve your problem ? if so , please just give me a hint because i have a similar one.
Best regards
Hassanain
Dear cchriste did you solve your problem ? if so , please just give me a hint because i have a similar one. Best regards Hassanain
Posted: 1 decade ago 23 mag 2013, 11:50 GMT-4
It has been a while, but I was trying to model how a beam would propagate through this Kerr-like material with different electrode structures, like a waveguide. I used the Comsol electrostatics physics to determine the applied electric field. I could then determine the index from these field variables, and then solved the beam propagation using differential equations with the index as a parameter.
I think I also tried to express the material index in terms of the applied electric field variables and use the EM physics package to calculate the beam propagation, but this was either too complicated or too slow, I am not sure. My approach with the DiffEqs sacrificed some physics but ended up being much easier.
I Hope that helps.
It has been a while, but I was trying to model how a beam would propagate through this Kerr-like material with different electrode structures, like a waveguide. I used the Comsol electrostatics physics to determine the applied electric field. I could then determine the index from these field variables, and then solved the beam propagation using differential equations with the index as a parameter. I think I also tried to express the material index in terms of the applied electric field variables and use the EM physics package to calculate the beam propagation, but this was either too complicated or too slow, I am not sure. My approach with the DiffEqs sacrificed some physics but ended up being much easier. I Hope that helps.
