Plz help on "Feature: Stationary Solver1(sol1/s1) Error: Failed to create folder to save to"
I am very new to COMSOL 4.1
Can anyone tell me why i am having the following error:
Regards
2 Replies Last Post 19 apr 2011, 17:25 GMT-4
Hello Faysal Khan
Posted: 1 decade ago 19 apr 2011, 17:20 GMT-4
I am also getting this error...
Posted: 1 decade ago 19 apr 2011, 17:25 GMT-4
The error you mentioned indicates that COMSOL is
unable to create recovery data on disk. Normally COMSOL saves the current
simulation into a recovery directory, which is located in a profile
directory in your home directory. If there is not enough space in your home
directory, or if the path to the home directory contains "non-standard"
characters, this problem may occur. Possible solution is:
Turn off the recovery feature. Start COMSOL 4.1, go to the menu
Options > Preferences > Save
and un-check the "Recovery" check box.
Regards
Faysal
[QUOTE] I am also getting this error... [/QUOTE] The error you mentioned indicates that COMSOL is unable to create recovery data on disk. Normally COMSOL saves the current simulation into a recovery directory, which is located in a profile directory in your home directory. If there is not enough space in your home directory, or if the path to the home directory contains "non-standard" characters, this problem may occur. Possible solution is: Turn off the recovery feature. Start COMSOL 4.1, go to the menu Options > Preferences > Save and un-check the "Recovery" check box. Regards Faysal
