Domain number Assignment
Dear All,
I wrote a code for my comsol multiphysics problem using comsol livelink matlab. The code is working and producing desired geometry but there is problem regarding domain number as comsol assign domain number itself .
Is there any way to assign domain number of one's need while working in comsol livelink matlab .
Please suggest some solution.
Asha Sharma
4 Replies Last Post 22 ago 2017, 07:04 GMT-4
Posted: 8 years ago 18 ago 2017, 15:33 GMT-4
Hello Asha,
See www.comsol.com/blogs/manually-work-entity-numbers-selections/
Hello Asha, See https://www.comsol.com/blogs/manually-work-entity-numbers-selections/ Best, Jeff
Posted: 8 years ago 18 ago 2017, 16:24 GMT-4
Hello Jeff,
Thank you for valuable suggestion.
But in my geometry, i am having 200 circles and can't let the material property to get changed within each domain. So i used 'for' loop while using 'ballselection' for 200circles as below:
numpart=200
for j=1:numpart
selball=(j);
ballsel1=strcat('c',selball)
partno=j;
ctxname=(ctx(partno));
ctyname=(cty(partno));
model.geom('geom1').create(ballsel1, 'BallSelection');
model.geom('geom1').feature(ballsel1).set('r', [radpart]);
model.geom('geom1').feature(ballsel1).set('posx', [ctxname]);
model.geom('geom1').feature(ballsel1).set('posy', [ctyname]);
model.geom('geom1').feature(ballsel1).set('condition', 'allvertices');
end
model.geom('geom1').run;
But its producing following error:
Error using PermittThreeCirc (line 46)
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: An object with the given name
already exists
(rethrown as com.comsol.util.exceptions.FlException)
An object with the given name already exists
An object with the given name already exists.
- Tag: ballsel1
Please suggest solution.
Hello Jeff, Thank you for valuable suggestion. But in my geometry, i am having 200 circles and can't let the material property to get changed within each domain. So i used 'for' loop while using 'ballselection' for 200circles as below: numpart=200 for j=1:numpart selball=(j); ballsel1=strcat('c',selball) partno=j; ctxname=(ctx(partno)); ctyname=(cty(partno)); model.geom('geom1').create(ballsel1, 'BallSelection'); model.geom('geom1').feature(ballsel1).set('r', [radpart]); model.geom('geom1').feature(ballsel1).set('posx', [ctxname]); model.geom('geom1').feature(ballsel1).set('posy', [ctyname]); model.geom('geom1').feature(ballsel1).set('condition', 'allvertices'); end model.geom('geom1').run; But its producing following error: Error using PermittThreeCirc (line 46) Java exception occurred: Exception: com.comsol.util.exceptions.FlException: An object with the given name already exists (rethrown as com.comsol.util.exceptions.FlException) (rethrown as com.comsol.util.exceptions.FlException) Messages: An object with the given name already exists An object with the given name already exists An object with the given name already exists. - Tag: ballsel1 Please suggest solution.
Posted: 8 years ago 22 ago 2017, 06:54 GMT-4
I can't see why your code should result in the error message you see. Can you send your model and script to support?
What type of variation of material parameters do you wish to have for each circle? Are all the parameters different or can you group the material settings?
You can either use different materials for different selections or you can define Variables (Component->Definitions->Variables) that use different expressions in different domains.
I would use the function mphselectcoords for finding the entity numbers. It works similarly to a BallSelection, but doesn't add selections to the model. You can then use the returned entity numbers when setting up your model.
Lars Gregersen
Comsol Denmark
Hi I can't see why your code should result in the error message you see. Can you send your model and script to support? What type of variation of material parameters do you wish to have for each circle? Are all the parameters different or can you group the material settings? You can either use different materials for different selections or you can define Variables (Component->Definitions->Variables) that use different expressions in different domains. I would use the function mphselectcoords for finding the entity numbers. It works similarly to a BallSelection, but doesn't add selections to the model. You can then use the returned entity numbers when setting up your model. -- Lars Gregersen Comsol Denmark
Posted: 8 years ago 22 ago 2017, 07:04 GMT-4
Hello Lars,
Thank you for your valuable suggestion.
This link www.comsol.com/blogs/manually-...ork-entity-numbers-selections/ worked for me.
Actually i was writing code like
Instead of
tag=model.geom('geom1').feature.uniquetag('ballsel');
model.geom('geom1').feature.create(tag, 'BallSelection');
Asha Sharma
Hello Lars, Thank you for your valuable suggestion. This link www.comsol.com/blogs/manually-...ork-entity-numbers-selections/ worked for me. Actually i was writing code like model.geom('geom1').create(ballsel1, 'BallSelection'); Instead of tag=model.geom('geom1').feature.uniquetag('ballsel'); model.geom('geom1').feature.create(tag, 'BallSelection'); ------------------ Asha Sharma
