Error 4100
HI there,
I perform a simulation on a motor using the AC/DC module-perpendicular induction currents,vector potential (emqa). My subdomains include, rotor, stator, air, shaft and winding area. When i am meshing it using finer mesh size, i get this error message displayed:
"Error 4100. Failed to generate mesh for subdomain 2. Subdomain 2: Internal error in advancing front mesher"
What does this mean? SHould i just use the normal mesh? will the result of flux be different between normal mesh and finer mesh size?
Thank you in advance for your time and help.
1 Reply Last Post 22 mar 2011, 02:25 GMT-4
Posted: 1 decade ago 22 mar 2011, 02:25 GMT-4
there are certainly cereal possibilities to generate this error. What I have noticed is that when you have a geometry that loop around torus or with a central cut, you often get such an error. What I do is to cut my geometry into a few parts and then mesh one by one, if the global meshing is not successful
Hi there are certainly cereal possibilities to generate this error. What I have noticed is that when you have a geometry that loop around torus or with a central cut, you often get such an error. What I do is to cut my geometry into a few parts and then mesh one by one, if the global meshing is not successful -- Good luck Ivar
