Quick question using MATLAB livelink
I am using COMSOL 4.1 with MATLAB to model an inductor. I am interested in extracting the inductance matrix and capacitance matrix. I have successfully implemented the algorithm to do so.
However, I am having the following trouble:
The matlab-scripts I wrote contains a loop in order to calculate the capactiance-matrix or inductance-matrix, respectively. In every iteration terminal-conditions of the model are altered and the Comsol-model is invoked.
The problem, is that Comsol is keeping the data (or results) for every run.
For example, after the 5th run, Comsol saved 5 times the amount of data gathered by a single run. So, after a certain amount of runs the physical memory of the computer is exhausted.
How can I delete the results from a preceding simulation-run to prevent from gathering to much data?
Any help is greatly appreciated.
1 Reply Last Post 11 apr 2011, 07:59 GMT-4
Posted: 1 decade ago 11 apr 2011, 07:59 GMT-4
I haven't tested it, but try:
model.sol('sol1').clearSolution;
Peter
Hi, I haven't tested it, but try: model.sol('sol1').clearSolution; Regards, Peter
