Laminar Flow and Heat Transfer
The below post is related to an archived discussion
Hello!
I am trying to model 3D laminar flow with heat transfer in a rectangular channel. I have coupled both the physics through the Multiphysics node. When I set the reference pressure pref as zero, I get the error message "Division by zero". As my model is not open to atmosphere, I do not want to keep the pref as 1[atm] (default value). Kindly provide your suggestions in this regard.
Thanks in advance.
1 Reply Last Post 23 mar 2018, 08:02 GMT-4
Erik Bornhöft COMSOL Employee
Posted: 7 years ago 23 mar 2018, 08:02 GMT-4
Dear Ankit,
do you maybe use a pressure dependent gas density? You might get a zero density then. Set the reference pressure according to your conditions. If it is close to vacuum you might want to consider molecular flow instead of laminar flow.
See also: https://www.comsol.com/blogs/how-to-assign-fluid-pressure-in-cfd-simulations/
And: https://www.comsol.com/blogs/what-is-molecular-flow/
Erik
Erik Bornhöft
COMSOL Germany
Dear Ankit, do you maybe use a pressure dependent gas density? You might get a zero density then. Set the reference pressure according to your conditions. If it is close to vacuum you might want to consider molecular flow instead of laminar flow. See also: https://www.comsol.com/blogs/how-to-assign-fluid-pressure-in-cfd-simulations/ And: https://www.comsol.com/blogs/what-is-molecular-flow/
