Function name
Posted 23 apr 2011, 02:20 GMT-4 Version 4.1 1 Reply
In V4, we can define the function name under the global definition>parameter
If water has been chosen,
For example,
Material: Water
Material properties: density (rho) and dynamic viscosity (mu)
All above has been specified by the software.
Under parameter, I would like to key in Re (Reynold number) as function name and the expression column, I key in the rho*V*L/mu. But there is showing invalid function name for 'rho' and 'mu'.
Thus, what should I key in the 'function name' that has been defined under the material properties in the parameter/ variable? Or, I still have to redefine the density and dynamic viscosity?
Looking forward to hearing from you guys.
Thanks a lot.
For example,
Material: Water
Thanks a lot.
1 Reply Last Post 23 apr 2011, 03:16 GMT-4
