Flow waves Oscillations using PDE Coefficients
Hi all!
I am new in COMSOL and in this moment I am trying to create flow waves in a pipe filled with a compressible fluid using the PDE Coefficients. The problem has been analliticaly solve using some approximations and boundary conditions for the Continuity Equation and Navier Stokes Equations, giving as a result that the Pressure and the axial and radial Velocity are traveling waves with a complex velocity, produccing an oscillation.
The problem consists in coupling three differential equations and I think I did that part well (I selected three physics and in each one I wrote the equation with its corresponding coefficients). Now I have doubt about the boundary conditions, in the module of Fluid Dynamics (Laminar Flow) the No Slip boundary condition (U(R)=V(R)=0, axial and radial velocity to be zero at the walls of the pipe) is already prescribed, but in the PDE Coefficients would be the equivalent for No Slip the Zero-Flux? Furthermore, to produce the oscillations I need to apply a Pressure Oscillation at the entrance of the Pipe so I decided to used Dirichlet BC at the top of my pipe and I prescribed the Pressure equation to be sin(wt), the result is not what I am expecting, For the Pressure I am getting for all the times the same Pressure I prescribed and also the results have an unreallistic order of magnitudes (10^150).
I already worked with the module of Fluid Dynamics and I tried to reproduce the same as the paper and I never obtained the oscillations, so then I decied to use the PDE coefficients to write exactly the equation that are used in the paper with the approximations considered there.
I would appriciate any idea and advice,
Victoria Jimenez.
1 Reply Last Post 16 apr 2018, 04:19 GMT-4
Johannes Gräwer COMSOL Employee
Posted: 6 years ago 16 apr 2018, 04:19 GMT-4
Dear Victoria Jimenez,
if your COMSOL license is on subscription, you can submit your questions via the Support Center for a comprehensive response from our Technical Support team.
Best Regards, Johannes Gräwer
Dear Victoria Jimenez, if your COMSOL license is on subscription, you can submit your questions via the [Support Center](https://www.comsol.com/support) for a comprehensive response from our Technical Support team. Best Regards, Johannes Gräwer
