ParametricSweep WITH AdaptiveMesh
Posted 3 mag 2011, 15:48 GMT-4 Parameters, Variables, & Functions, Studies & Solvers Version 4.1 3 Replies
I solve the temperature in a rectangle, with temperature given on the boudaries. The temperature T(x,y) is solved with "Adaptive Mesh Refinement". Then, many rectangles with different "Heigth" are solved with a "Parametric Sweep".
The problem is that the solutions stored are the solution with the initial mesh of each geometrie, but i cant find the solution obtained with the adapted mesh for those geometrie.
Can anyone tell me what I have to do to store the "adapted mesh" result, for each geometrie of the parametric sweep ?
I joined the .mph.
Thank you.
Université Laval
I joined the .mph.
Thank you.
Université Laval
3 Replies Last Post 5 mag 2011, 10:37 GMT-4
