Periodic load using a defined function?
I would like to solve a time dependent problem. For that I would like to define a periodic load on one of the boundaries in my geometry. My question is if it is possible to first define a function, e.g. "Model -> Definitions -> Functions ->Waveform -> Triangle" and then use this function as a time dependent load? I have tried to do that by first defining a waveform function called "wv1". But when I put "wv1" in the "Boundary Load", the line turns red and the solver gives me an error saying that it failed to evaluate variable wv1.
Thanks in advance,
Yuriy
2 Replies Last Post 30 mag 2016, 11:53 GMT-4
Posted: 1 decade ago 6 mag 2011, 09:13 GMT-4
"ww1" is not a "variable", it's an "operator", you should use it as ww1(t[1/s]) the t[1/s] is to make the time "t" unitless as operators want unitless input
Hi "ww1" is not a "variable", it's an "operator", you should use it as ww1(t[1/s]) the t[1/s] is to make the time "t" unitless as operators want unitless input -- Good luck Ivar
Posted: 8 years ago 30 mag 2016, 11:53 GMT-4
thank you so much
thank you so much
