failed to find consistenet initial values
what should I do with this error ?
and My MUMPS allocation factor increased . if i do not now anything about the initial values of my problem , what should I do ?
should I change the solver ?
I have multiphysics problem and I use Transient Initialization solver too before my time dependent.
what should I do to get rid off this error ?
thanks
3 Replies Last Post 24 mag 2011, 10:40 GMT-4
Posted: 1 decade ago 24 mag 2011, 10:11 GMT-4
I would rather look at the BCs and the initial values, probably you are start too far off the final result and the solver does not amange to get a fixed starting point, or you have one or several of your variables that are no continuous arounf the starting point.
I do not believe it's primarly a solver issue
Hi I would rather look at the BCs and the initial values, probably you are start too far off the final result and the solver does not amange to get a fixed starting point, or you have one or several of your variables that are no continuous arounf the starting point. I do not believe it's primarly a solver issue -- Good luck Ivar
Posted: 1 decade ago 24 mag 2011, 10:12 GMT-4
if I do not know the approximate range of my answers , what should I do ?
Posted: 1 decade ago 24 mag 2011, 10:40 GMT-4
in may cases a reasonable guess, even a linear extrapolation is better than just "0"
Hi in may cases a reasonable guess, even a linear extrapolation is better than just "0" -- Good luck Ivar
