Helical coil meshing in comsol 4.1
Hi.
I'm meshing a helical coil drawing with comsol 4.1 helix primitive. My idea was to perform a sweep meshing. So I meshed the start boundary with free triangular and then I added a sweep meshing where I indicated the start boundary the stop boundary and the element distribution.
Trying with different configurations I had the same error "Inverted element"
Any idea
Regards
3 Replies Last Post 14 giu 2011, 08:31 GMT-4
Posted: 1 decade ago 14 giu 2011, 06:40 GMT-4
**Removed by Author***
Posted: 1 decade ago 14 giu 2011, 07:57 GMT-4
Ali, what you posted is incorrect, the swept mesher does support changes in directions and changes in the cross-section. Javier, please see the attached screenshot which shows a swept mesh used to mesh a helix. All settings in the Helix 1, Free Triangular 1 and Swept 1 nodes are default.
Posted: 1 decade ago 14 giu 2011, 08:31 GMT-4
My bad, i did not intend to give false information but I had a similr experience with sweeping ( I still have) where comsol simply fails to sweep through a volume with a change in cross section. Thank you for the hint though
[QUOTE] Ali, what you posted is incorrect, the swept mesher does support changes in directions and changes in the cross-section. Javier, please see the attached screenshot which shows a swept mesh used to mesh a helix. All settings in the Helix 1, Free Triangular 1 and Swept 1 nodes are default. [/QUOTE] My bad, i did not intend to give false information but I had a similr experience with sweeping ( I still have) where comsol simply fails to sweep through a volume with a change in cross section. Thank you for the hint though
