automatic 2D plots scaling in COMSOL 4.2
Dear all,
I'm experiencing some trouble while plotting a 2D graphic with COMSOL 4.2.
I try to simulate the effect of the centrifugal force on a rotor for several rotational speeds using the continuation option of the stationary solver (here 30'000rpm and 40'000rpm). It should actually not be a tricky task at all. However when I want to plot the radial deformation (sqrt(u^2+v^2)) of point (2Dplot>point graph) COMSOL is making a funny plot scaling. Even though I have set the parameter value to 'all', COMSOL is scaling the graphic around the last parameter value, which means I do not even see the point corresponding to the 1st parameter value and the line seems totally horizontally because the y-axis scale is ranging between 1 and -1[m] (and the deformation order of magnitude is 1e-5[m]). It is kind of annyoing since it means I have to first look what is the magnitude of order of the deformation (using the derived value) and then to manually set the axis.
If I am carrying out the simulation for 3 rotational speeds instead of 2, COMSOL scales the graphs properly.
Does anybody know this issue? Am I doing something wrong or is it a known-bug?
Vincent
3 Replies Last Post 14 lug 2011, 06:57 GMT-4
Posted: 1 decade ago 23 giu 2011, 09:42 GMT-4
Vincent,
I resolved some similar issues (however in 4.1) in 2D plots by switching the 2D rendering from Swing to SWT in Options>Preferences>2D rendering.
I have no idea what the underlying issue is.
Cheers
Edgar
Vincent, I resolved some similar issues (however in 4.1) in 2D plots by switching the 2D rendering from Swing to SWT in Options>Preferences>2D rendering. I have no idea what the underlying issue is. Cheers Edgar
Posted: 1 decade ago 23 giu 2011, 10:12 GMT-4
Hi Edgar,
Thanks for the answer... However this option seems to not exist anymore in 4.2 :-( I played a little bit with the other options contained in option>preferences> graphics but none seems to solve this issue.
Regards
Vincent
Hi Edgar, Thanks for the answer... However this option seems to not exist anymore in 4.2 :-( I played a little bit with the other options contained in option>preferences> graphics but none seems to solve this issue. Regards Vincent
Posted: 1 decade ago 14 lug 2011, 06:57 GMT-4
Have you got anywhere with this? I'm having SWT related problems with 4.2 I'd *love* to resolve this way...
