problem with parameter sweep (Comsol4.2)..
Posted 22 ago 2011, 07:43 GMT-4 RF & Microwave Engineering, Structural Mechanics Version 4.2 3 Replies
I have a wierd problem with paramteric sweep. I have a linear elastic, structural mechanics , stationary problem and I want to vary the young's modulus to see the effects.
When I put the more than 2 values in the parametric sweep, Comsol gives me an error, saying:
Failed to find a solution for all parameters,
even when using the minimum parameter step.
No convergence, even when using the minimum damping factor.
However, the wierd part is when I ran the values separately, manually on Comsol, OR when I put <= 2 values in the parametric sweep, it gives nice converging solutions...
Any ideas?
Thanks in advance
Thuan Beng.
Hello Thuan Beng Saw
