Weak term in 4.1
Dear, all
I am just following the model "www.comsol.com/community/exchange/118/"
which is modeling the free surface motion.
That is made in version 3.5 a
I found difficulty in the WEAK TAB
3.5 : Equation system >Physics>Boundary settings>Weak>Pressure>u, v
4.1 : Laminar flow>weak contribution(?)
There are no "u, v" tab in 4.1 weak contribution .
How can i apply 3.5 boundary condition to the same in 4.1 ?
Any comments will be appreciated.
2 Replies Last Post 6 set 2011, 06:36 GMT-4
Posted: 1 decade ago 6 set 2011, 04:37 GMT-4
in V4 you type in your equations, with the variables you need, to see them and to cmpare to 3.5 the easiest is to turn on the equation view (sub-nodes) and compare from there
The GUIs are different, but the underlying eqautions are the same to the variable naming convention that differ a bit ;)
Hi in V4 you type in your equations, with the variables you need, to see them and to cmpare to 3.5 the easiest is to turn on the equation view (sub-nodes) and compare from there The GUIs are different, but the underlying eqautions are the same to the variable naming convention that differ a bit ;) -- Good luck Ivar
Posted: 1 decade ago 6 set 2011, 06:36 GMT-4
Great Thanks :)
Great Thanks :)
