End of file reached. Can't save file.
Posted 30 gen 2019, 10:20 GMT-5 General, Studies & Solvers, System Requirements Version 5.3a 0 Replies
The below post is related to an archived discussion
[start here] HI all, not sure of what the resolution to the referred thread was. I am also seeing a similar issue: End of file reached - File block size 39658832. Could someone explain what does that mean ? I cannot clear the mesh and solution as that will drain the sims of the results i'm trying to look. There are definitely a lot of points involved.
Hello Sudhansu Mishra
