pulse laser model using the function flc2hs
Hi, everyone, I’m studying (totally a strange one) the COMSOL to model the pulse laser, I have searched some useful models and tips from this web, but when I try to build the model myself, it seem to a big challenge. One of the problems is about the function flc2hs.
The parameter in the function flc2hs (t-start point, the width of transition), the actual definition of the second term in the bracket, I just call it like this temporarily because it presents the slope/width of the transition. But the different value of the two parameters presents various photogram, just illustrated as follow:
When the function:
1. flc2hs(t-5e-1,1e-14)-flc2hs(t-8e-1,1e-14)
2. flc2hs(t-5e-2,1e-14)-flc2hs(t-8e-2,1e-14)
3. flc2hs(t-5e-9,1e-14)-flc2hs(t-8e-9,1e-14)
When the start point is becoming smaller, the pulse (the y data are 1) is less evident and finally disappear to present a horizontal line (all the y data are zero). How do I should do to obtain the pulse using this function?
Thanks to all in advance.
sorry it seems that i can't attach the photos.
2 Replies Last Post 10 ott 2011, 11:15 GMT-4
Posted: 1 decade ago 28 set 2011, 04:28 GMT-4
in V4 you have the functions predefined as step or pulse, and you can combine those, and plot them beforehand rapidly ;)
if you then solve in temporal, do not forget to use strict or intermediate time stepping with a time step that resolves with a few points each ramp region, otherwise the "automatic" stepping timer will most probably jump over your pulses
Hi in V4 you have the functions predefined as step or pulse, and you can combine those, and plot them beforehand rapidly ;) if you then solve in temporal, do not forget to use strict or intermediate time stepping with a time step that resolves with a few points each ramp region, otherwise the "automatic" stepping timer will most probably jump over your pulses -- Good luck Ivar
Posted: 1 decade ago 10 ott 2011, 11:15 GMT-4
thanks very much, I just plot it to test if it's right.
