problem with time dependent phase transition model
Hi all,
I've built a model which involves a phase transition.
I want to see how long does it take for the phase transition to occur.
when I run the model with range(0,2,800) it gives logical results
with the typical graph of temperature vs. time where the temperature stays the same
as long as the phase transition occurs. But, when I run with (0,2,900), the phase
transition disappears and I get a graph with a continues temperature rise.
Is there anyone who encountered the same problem or has a solution?
thank you,
Zvika
2 Replies Last Post 10 set 2013, 13:19 GMT-4
Posted: 1 decade ago 24 ott 2011, 01:21 GMT-4
I can make a guess, it might be something else, but when you give a series to the solver, and leave the solver settings to default "Automatic" the solver will not solve strictly at each point you give, but might skip several, depending on the Jacobian of your system (derivative of the variables), so if you reach a regular intercase, the solver might skip over the non-linear transition. Try to use an "intermediate" or "strict" stepping method. See the solver node settings
Hi I can make a guess, it might be something else, but when you give a series to the solver, and leave the solver settings to default "Automatic" the solver will not solve strictly at each point you give, but might skip several, depending on the Jacobian of your system (derivative of the variables), so if you reach a regular intercase, the solver might skip over the non-linear transition. Try to use an "intermediate" or "strict" stepping method. See the solver node settings -- Good luck Ivar
Posted: 1 decade ago 10 set 2013, 13:19 GMT-4
hi
can the phase transition be stimulated in microchannel?
which module will give the best result??
thanks
ajith
hi can the phase transition be stimulated in microchannel? which module will give the best result?? thanks ajith
