Input Gaussian Beam (2d Grating coupler)
Hi Everyone,
I'm trying to produce a 2-D grating coupler simulation similar to that demonstrated here:
www.comsol.com/papers/4980/
I'm stuck at the point where I need to define an input Gaussian beam. I have defined the input port and enabled wave excitation, but regardless of what other values/settings I use, I will always get zero electric field everywhere.
To simplify things I threw away my model and just started with a simple box and set one side as the input port and tried to observe a plane wave propagating and still I don't see anything, so clearly I'm not implementing the input correctly.
Does anyone have any ideas?
Thanks in advance.
2 Replies Last Post 18 gen 2012, 16:36 GMT-5
Hello Norman Fong
Posted: 1 decade ago 3 gen 2012, 08:08 GMT-5
I'm also interested in this kind of simulations.
I had some ideas to proceed in the 3.5 version, but here the accessible parameters on the 4.2 are quite different.
I tried without success with the "Plasmonic Wire Grating" Model. It seems to be a good start because the angle of incidence is simulated and the S11 parameter give directly the reflection spectra.
I also tried by starting from this model: www.comsol.com/showroom/documentation/model/6141/ without success either.
Let us know if you progressed!
Regards.
Hi I'm also interested in this kind of simulations. I had some ideas to proceed in the 3.5 version, but here the accessible parameters on the 4.2 are quite different. I tried without success with the "Plasmonic Wire Grating" Model. It seems to be a good start because the angle of incidence is simulated and the S11 parameter give directly the reflection spectra. I also tried by starting from this model: http://www.comsol.com/showroom/documentation/model/6141/ without success either. Let us know if you progressed! Regards.
Posted: 1 decade ago 18 gen 2012, 16:36 GMT-5
here is a good starting point for plane wave: www.comsol.com/showroom/gallery/8610/
here is a good starting point for plane wave: http://www.comsol.com/showroom/gallery/8610/
