Electrowetting modeling questions
Posted 14 ott 2019, 10:47 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD), Microfluidics Version 5.4 1 Reply
Good morning. I followed the "Electrowetting Lens" example from the Application Gallery. The original model works well. Then I try to change the shape and material of the two fluids. I want to simulate the contact angle changing of a droplet on a dielectric film when appling voltage. But some errors happened when computing. It shows "Repeated error test failures. May have reached a singularity. Last time step is not converged." I attached my mph file. How could I solve this problem to run this model sucessfully? Thank you in advance.
