How to find reattachment length in Backward Facing step flow
Vaitheeswaran Gnanaraj
I am using CVOMSOL to Model the gas flow through microcahnnel. I wish to find the reattachment length of nitrogen gas. How to find it using COMSOL 3.5a
3 Replies Last Post 25 dic 2011, 08:21 GMT-5
Posted: 1 decade ago 24 dic 2011, 14:24 GMT-5
you can calculate the streamline with zero velocity as shown in the model "Turbulent Flow Over a Backward Facing Step". Another way is the check where the wall shear stress changes direction.
J
Hi, you can calculate the streamline with zero velocity as shown in the model "Turbulent Flow Over a Backward Facing Step". Another way is the check where the wall shear stress changes direction. Best, J
Posted: 1 decade ago 24 dic 2011, 23:50 GMT-5
Thank you for your reply. How to plot rattachment length versus Re
Posted: 1 decade ago 25 dic 2011, 08:21 GMT-5
Probably the best way is to export the data and to use Matlab, at least that's what I do. Perhaps you can find the coordinate of the limiting streamline at the wall and plot that one against the Re, but normally I do the post-processing outside COMSOL.
J
Probably the best way is to export the data and to use Matlab, at least that's what I do. Perhaps you can find the coordinate of the limiting streamline at the wall and plot that one against the Re, but normally I do the post-processing outside COMSOL. J
