Plot the change of a variable over the whole simulation time in one point
Hey guys,
I have an easy problem, buts its hard for me to solve...
I want to plot then change of a variable (temperature, pressure and so on...) over the whole simulation time in one specific point of my choice of my geometry.
The problem is to tell Comsol, which specific point I likte to have. How can I do this?
Without any problems it is possible to plot the status of all points for a specific timepoint. I do not want to though. Can someone help me there?
Greetings
1 Reply Last Post 19 gen 2012, 15:14 CET
Posted: 1 decade ago 19 gen 2012, 15:14 CET
either the point, line, boundary exist, and you can integrate or average over this element in a derived variable, that makes a table over time, and then you plot that
if the element does not already exist in the geometry, you need to make a derived data set (point, line cut plane ...) from the solution data set and then plot there on
Hi either the point, line, boundary exist, and you can integrate or average over this element in a derived variable, that makes a table over time, and then you plot that if the element does not already exist in the geometry, you need to make a derived data set (point, line cut plane ...) from the solution data set and then plot there on -- Good luck Ivar
