Question on Time Step Dependent study
Hi ,
I wish to conduct a time step dependent study for a time dependent simulation. I.e to say, run the same simulations with different time step. As the time step is smaller , it should be able to get a more accurate result as compared to a larger time step.
I wish to compare the difference in performance for the different time step.
However according to what i read through for comsol , COMSOL pick its internal time step own time step when running.The time step that we enter are the time step we want to see for the solutions. The internal time step is controlled by changing the tolerances.
I wish to ask if the program can be forced to conduct the simulated at a define time step like t=1, t=0.1 without changing its tolerance?
i noticed that the time step can adjust under steps taken by solver , from the option of free to Intermediate and strict. Does this change the time step in which the program simulate or it just displaying the time step according to the solution needed?
i hope i have not confuse any of you. feel free to clarify with me
Tim
5 Replies Last Post 29 feb 2012, 13:17 GMT-5
Posted: 1 decade ago 20 gen 2012, 16:54 GMT-5
use the contextual help most answers are therein.
Indeed "free" mode is for COMSOL decided time steps, excellent for diffusion problems, but unlucky for periodic BC conditions.
Intermediate, take the user defined ones, but still might add a few in-between if the results are poor
Strict is only solving for the values you define
Hi use the contextual help most answers are therein. Indeed "free" mode is for COMSOL decided time steps, excellent for diffusion problems, but unlucky for periodic BC conditions. Intermediate, take the user defined ones, but still might add a few in-between if the results are poor Strict is only solving for the values you define -- Good luck Ivar
Posted: 1 decade ago 21 gen 2012, 00:06 GMT-5
Thanks Ivar !! Great help. !
[QUOTE] Hi use the contextual help most answers are therein. Indeed "free" mode is for COMSOL decided time steps, excellent for diffusion problems, but unlucky for periodic BC conditions. Intermediate, take the user defined ones, but still might add a few in-between if the results are poor Strict is only solving for the values you define -- Good luck Ivar [/QUOTE] Thanks Ivar !! Great help. !
Posted: 1 decade ago 29 feb 2012, 11:05 GMT-5
Hi Ivar,
I changed the time stepping to Strict, but the time steps in the LOG are still not matching with my defined time steps. I just want the solver to use the exactly my time steps. what should i do ?
Hi Ivar, I changed the time stepping to Strict, but the time steps in the LOG are still not matching with my defined time steps. I just want the solver to use the exactly my time steps. what should i do ?
Posted: 1 decade ago 29 feb 2012, 13:11 GMT-5
normally it tries to use only yours, but if it fails it still tries to take smaller steps to get on line again, probably you have too tough initial conditions compared to your BC.
And are you in BDF or Gen-alpha ?
Hi normally it tries to use only yours, but if it fails it still tries to take smaller steps to get on line again, probably you have too tough initial conditions compared to your BC. And are you in BDF or Gen-alpha ? -- Good luck Ivar
Posted: 1 decade ago 29 feb 2012, 13:17 GMT-5
I am using BDF, I have a periodic BC ( time dependent) , so that is the reason I change free to strict in my solver.
