1 mar 2012, 22:03 CET
not that I think it should change the results (but perhaps) now in V4 you do not need to define "pairs" and use assembly mode for geometry in contact with "thin" physics, as you have the standard "Contact Impedance" that overrides the default Union continuity, they behave the same from my understanding
In anycase, if you use the Assembly mode, I would use "create imprint"s to limit the contact pair region to the two overlapping boundaries and not include the full L shape area
1 mar 2012, 23:44 CET
Hi, Ivar,
thanks for the reply.
I followed your advice: on the "finalize" node, I now chose "form union" over "form assembly" ( the reason I chose "form assembly" earlier is because someone did for me since I am new to COMSOL). then those "identity pairs" despair,and the "pair contact impedance" is useless too. so I use "contact impedance" instead now. and with another change in my model, here I use "external potential" on the top surface of the "square" electrode to account for the incoming current, where i used to use "normal current density". with above modification, the model seems work well. thanks.
but if I use "normal current density" to account for the incoming current, my results looks funny. I am curious which boundary condition should be used for the external current in common DC current structure. for example, if you want current to flow in one electrode and flow out from another electrode.
the modified version is attached too.
regards,
Hi, Ivar,
regards,
1 mar 2012, 23:56 CET
I would propose to use a "terminal" in current or voltage mode, this lumped BC sets an average value over the boundary, but gives you directly in the "Results - Derived Values - Global Evaluations" sub nodes the impedances currents and voltages, so you do not need to bother about surface integrations
2 mar 2012, 00:46 CET
Ivar,
I tired to use "terminal" to account for the external current, it works very well. thanks.
actually I once considered to use it, but I find out in COMSOL help file: under the entry "Boundary Conditions for the Electrostatics Interface", "terminal" is listed as one of "Interior Boundaries", also as one of "Exterior Boundaries". I don't understand the difference between the 2 situations, so I decide to drop it. but glad it works out at the end.
regards,
Ivar,
regards,
2 mar 2012, 07:27 CET
for me in ES or EC there is no difference for internal or external Terminal BCs.
However in MF or MEF there are some issues with the consisitency of terminal and physics. For the magnetic field one need to have a current loop (a full one) as one cannot have a current source appearing in 3D space like that, and dissapearing somewhere else in the middle of our model, that is not "physical" we need to lead the current back to form a loop. In 2D there is the workaround to say the current loops out of the plane, and we solve for only some of the full vector field
5 mar 2012, 21:16 CET
Hi, Ivar,
thanks for the explanation. back to this model, I had another simple question: what if I wan to get average value over a specific area?
in my case, I am calculating the electrical potential over my 3D structure. On any boundary surface, I could use "results ---->derived value----->average--->surface average" to calculate the electrical potential over the whole surface which is selected boundary. but what if I am only interested in part of one boundary surface. how can I do it? for example , if I only want to calculate the average over a specific area of 1x2um on my "L" shape mesa.
regards,
Hi, Ivar,
regards,
