Use of Matlab functions in the Application Builder
Hi!
How can I use the Matlab functions (.m files) in Comsol Application Builder? (I’m using Comsol 5.5) I have several complex Matlab functions that I use for post-processing of acoustic simulations, but I don't know how to use these functions in the application builder.
My idea is to provide some arguments to a Matlab function, then the function elaborates the data and finally I can use the results.
Thanks!
Leonardo
1 Reply Last Post 16 ott 2020, 03:27 GMT-4
Posted: 5 years ago 16 ott 2020, 03:27 GMT-4
I solved!
I created the app from the Matlab script with a very simple GUI that can be only a progress bar or a dialog box (or inputdlg if there are some arguments), then I added the file in the Comsol Application Builder Library (Library->Files).
To use the Matlab function, can be used the command "fileOpen("embedded:\\YourApplication")" in a Comsol Application Builder method.
I solved! I created the app from the Matlab script with a very simple GUI that can be only a progress bar or a dialog box (or inputdlg if there are some arguments), then I added the file in the Comsol Application Builder Library (Library->Files). To use the Matlab function, can be used the command "fileOpen("embedded:\\\YourApplication")" in a Comsol Application Builder method.
