Terminal Boundary Condition
Hi everyone,
I'm currently trying to model a capacitor and am having difficulty introducing a voltage to the system. In the picture shared, the upper and lower plates were assigned the aluminum material and the middle plate is assigned acrylic plastic to represent a dialectric.
I've seen other threads before discussing the "terminal" boundary condition, which supposedly simulates a terminal hooked up to an outside circuit that can simulate electron flow and induce a voltage drop or some sort of capacitance across the model. The only issue is that the "terminal" condition simply refuses to show up in my COMSOL. I can't find it anywhere - in the AC/DC module, in the help bar, basically it seems that it doesn't exist on my computer. Has anyone else run into a similar problem? Are there other ways to achieve this capacitor simulation I'm going after that don't involve terminal?
Thanks so much! !
2 Replies Last Post 26 nov 2020, 12:14 GMT-5
Posted: 4 years ago 25 nov 2020, 13:57 GMT-5
Hello Kendall,
The most likely explanation is that the license you are using does not include the AC/DC Module, Plasma Module, MEMS Module or Semiconductor Module (Those four optional add-on products are the ones that include the Terminal condition). Note that a folder marked "AC/DC" will appear in the Model Wizard whether or not your license includes the AC/DC Module; this is because there are capabilities in the field of AC/DC modeling that are included in the core COMSOL Multiphysics. To determine if your license does in fact include one of those modules, you need to go to File > Licensed and Used Products.
Jeff Hiller
Hello Kendall, The most likely explanation is that the license you are using does not include the AC/DC Module, Plasma Module, MEMS Module or Semiconductor Module (Those four optional add-on products are the ones that include the Terminal condition). Note that a folder marked "AC/DC" will appear in the Model Wizard whether or not your license includes the AC/DC Module; this is because there are capabilities in the field of AC/DC modeling that are included in the core COMSOL Multiphysics. To determine if your license does in fact include one of those modules, you need to go to File > Licensed and Used Products. Best regards, Jeff
Dave Greve Certified Consultant
Posted: 4 years ago 26 nov 2020, 12:14 GMT-5
Capacitance calculations can often be performed using the Potential boundary condition, and integrating the normal electric displacement vector to find the electrode charge.
