Electric field propagation axis
I am new to COMSOL and I have been using it for a few days. I created a model for an optical waveguide (Cylinder). after computation, the electric field was not propagating (z axis was the propagation direction). When I modified the geometry and made the x axis to be the propagation direction, the problem is solved. Why is that? You can also see the attached snapshots.
4 Replies Last Post 28 nov 2020, 11:54 GMT-5
Dave Greve Certified Consultant
Posted: 4 years ago 26 nov 2020, 12:16 GMT-5
It's only possible to make guesses if you don't post the model.
One guess is that you are using the port boundary condition incorrectly.
It's only possible to make guesses if you don't post the model. One guess is that you are using the port boundary condition incorrectly.
Posted: 4 years ago 27 nov 2020, 08:54 GMT-5
I have attached the model, you need to extract it with 7zip program.
Posted: 4 years ago 27 nov 2020, 18:48 GMT-5
Perhaps someone can decompress that file. I can't.
Consider following the instructions below about reducing the mph file size, and then posting the file.
Perhaps someone can decompress that file. I can't. Consider following the instructions below about reducing the mph file size, and then posting the file.
Posted: 4 years ago 28 nov 2020, 11:54 GMT-5
I have reuploaded it with zip compression. Could you please check it?
