Hello Ming-Yi Yen
27 gen 2013, 13:26 GMT-5
I have the same problem when trying to use the k-omega turbulence model. The problem doesn't occur when using the k-epsilon model, but the k-epsilon crashes because the solution diverges. At least I can get some preliminary results from the successful iterations with the k-epsilon, but I can't get a solution at my full velocity value.
23 set 2013, 03:52 GMT-4
You need to add a new study. The old study does update correctly the solver when you change the turbulence model.
10 years ago
27 set 2014, 20:49 GMT-4
This is great. Thanks Stanimir. It solved my problem.
9 years ago
14 mag 2015, 14:28 GMT-4
Hi Yi Ming
i am facing the same problem , i am trying to study converging diverging nozzle with high mach number at the exit.
can you suggest, if you found any solution around your problem.
or if you can send your model for reference , it would be really helpful for me.
regards Mehlam
Hi Yi Ming
regards Mehlam
9 years ago
19 ott 2015, 16:30 GMT-4
No solution yet?
Not even an idea about this variable?
No solution yet?
9 years ago
10 nov 2015, 07:23 GMT-5
Thanks Stanimir. I had also same problem but ı solved now, ı want to say hat thanks again :D
