Piezoelectric transformer interfaced with electrical circuit.
I have made a piezo transformer model and wish to drive it using an external electrical circuit interface.
I have made connections to the electrical circuit elements using a voltage source, a small input resistor and a load at the output terminal.
It is basically a 3-terminal device, wherein the input and output electrodes have a common ground.
After doing a frequency domain study, I get the following error:
Failed to find a solution for the initial parameter.
Maximum number of segregated iterations reached.
I'm not sure if the error is with the electrical circuit interface or something to do with the meshing/tolerance/solver since the model simulated fine before addition of the electrical circuit interface, plotting susceptance and electrical potential.
Anyone who would be able to throw some light, it would be of great help to me. I have attached the model and the diagrammatic representation of the entire model.
Thanks!
Sneha
2 Replies Last Post 17 dic 2012, 01:38 GMT-5
Hello Sneha Lele
Posted: 1 decade ago 16 dic 2012, 20:06 GMT-5
Now,I have found the same error too.And also in my model Piezoelectric Devices is the first nodal ponit. I want to know if you have found the soulation of it.Thank you very much!
Posted: 1 decade ago 17 dic 2012, 01:38 GMT-5
your "spring foundation" with "0" stiffness will certainly give you some issues, forthermore I expect your are missing a GND for the second PZT
Then if its "just to put a voltage sinus source you can as well set it directly into the terminal, no need for the "Circuit" physics for that, and for the passive resistance, you can use the Terminal load settings
Then use at least 3 or more mesh elements across the thickness (my way is to split all such blocks with a layer or more)
Hi your "spring foundation" with "0" stiffness will certainly give you some issues, forthermore I expect your are missing a GND for the second PZT Then if its "just to put a voltage sinus source you can as well set it directly into the terminal, no need for the "Circuit" physics for that, and for the passive resistance, you can use the Terminal load settings Then use at least 3 or more mesh elements across the thickness (my way is to split all such blocks with a layer or more) -- Good luck Ivar
