Time dependent surface concentration?
Hi All
I'm trying to test a cylindrical model against an analytical solution for a simple diffusion model and would like the surface concentration of one of the variables to be a ramp. I generate a ramp function but can't use a boundary condition for a variable like:
1e-6*ramp1
Its displayed in red and the Jacobian can't be evaluated. How can I make the surface concentration a function of time?
Many thanks for your help with this steep learning curve...
Mark
2 Replies Last Post 25 mag 2012, 10:34 GMT-4
Posted: 1 decade ago 24 mag 2012, 18:02 GMT-4
your ramp1() is an operator you need to define a variable to drive the ramp.
Either you have a defined "Parameter" ie Param, and you adapt Param from the steady state solver continuation tab
then you write
1e-6[your_units]*ramp1(Param)
or you have a time dependent analysis, in which case you use t in seconds to drive your ramp opertor with a
1e-6[your_units]*ramp1(t[1/s])
the t[1/s] is to remove any units and use a time stepping in seconds as operators do not expect units as arguments
Hi your ramp1() is an operator you need to define a variable to drive the ramp. Either you have a defined "Parameter" ie Param, and you adapt Param from the steady state solver continuation tab then you write 1e-6[your_units]*ramp1(Param) or you have a time dependent analysis, in which case you use t in seconds to drive your ramp opertor with a 1e-6[your_units]*ramp1(t[1/s]) the t[1/s] is to remove any units and use a time stepping in seconds as operators do not expect units as arguments -- Good luck Ivar
Posted: 1 decade ago 25 mag 2012, 10:34 GMT-4
Many thanks, that seemed to do it. Now I've to try to understand why point graphs don't adopt the new integration interval etc...
Cheers Mark
Many thanks, that seemed to do it. Now I've to try to understand why point graphs don't adopt the new integration interval etc... Cheers Mark
