How to draw magnetic field arrows?
José Román Bilbao-Castro
Hi all,
I have successfuly followed the "Magnetic Lens" example. Nevertheless, I would like to see the field arrows on the screen but I am not able to do it. Any hints on how to achieve this?. I would like to get the typical drawing like:
hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html
Thanks in advance,
Jose.
3 Replies Last Post 29 mag 2012, 10:08 GMT-4
Posted: 1 decade ago 29 mag 2012, 09:20 GMT-4
I'm not sure, but you should try using Streamline.
Posted: 1 decade ago 29 mag 2012, 09:39 GMT-4
have you tried to add the Plot Arrow Volume or Surface (depending on your plot type) ?
I often prefere streamlines on 2D cut surfaces.
Also in certain cases you need to tweak the arrow type and number
Hi have you tried to add the Plot Arrow Volume or Surface (depending on your plot type) ? I often prefere streamlines on 2D cut surfaces. Also in certain cases you need to tweak the arrow type and number -- Good luck Ivar
Posted: 1 decade ago 29 mag 2012, 10:08 GMT-4
Thanks for your replies. I have managed to see the lines using streamlines, but I would also like to see them showing the arrows representing the flow direction. I will try with the rest of your comments...
Jose
Thanks for your replies. I have managed to see the lines using streamlines, but I would also like to see them showing the arrows representing the flow direction. I will try with the rest of your comments... Regards, Jose
