boundary condition
Hi:
What are the boundary condition nécaisaire to the coupling between an ability by the electrostatic model and the model electric circuit?
(The goal is the realization of a capacitive divider)
thank you.
1 Reply Last Post 6 giu 2012, 16:20 GMT-4
Posted: 1 decade ago 6 giu 2012, 16:20 GMT-4
check the doc and the model library examples:
try a "Terminal" and a GND in the ES or EC physics , then link xout Terminal to CIR, and add a I vs U (or U vs I depending on your model) in the CIR physics, then link this node to the corresponding Terminal (pull down menu)
Hi check the doc and the model library examples: try a "Terminal" and a GND in the ES or EC physics , then link xout Terminal to CIR, and add a I vs U (or U vs I depending on your model) in the CIR physics, then link this node to the corresponding Terminal (pull down menu) -- Good luck Ivar
