deformation of a moving submerged object
Hi All,
I'm a beginner of the Comsol. I have to model the deformation of a submerged flexible object. I use FSI model, but I'm wondering that the motion and deformation of this circular object can be modeled or not. I f any one have a clue. please help me. so far I developed a model to analyse the deformation of an fixed object, but it does not show any deformation.
Please help me.
2 Replies Last Post 12 giu 2012, 17:38 GMT-4
Posted: 1 decade ago 12 giu 2012, 01:46 GMT-4
first I would advise to read carefully a few times the different docs, as FSi is already complex physics and there are many things to learn.
a few tips:
use Parameters for contant values and not Variables, use variables for things that might change during the simulation or depend on the simulation results
Point constraints are tricky, try using as far as possible boundary constraints (your fixed "point" replace it by a small circle and fix the boundary of the circle
You are in 2D, be aware that this means flow between two plates 1 meter deep (nothing wrong with that but its not 100% as a round "tube/pipe"
Mesh, try the default physics meshing, as yours has no boundary layer and will not easy the convergence of the solver
You have noslip conditions, this mans that the flow has "0" velocity at the walls, but you impose a flat inlet velocity, its better to use a parabolic velocity profile or a laminar inflow
turn on the "defomration" node to see your "solid" deform
Check the Reanold cell number, just to be sure you are in a good laminar regime (the case I see but it's good practice anyhow)
Hi first I would advise to read carefully a few times the different docs, as FSi is already complex physics and there are many things to learn. a few tips: use Parameters for contant values and not Variables, use variables for things that might change during the simulation or depend on the simulation results Point constraints are tricky, try using as far as possible boundary constraints (your fixed "point" replace it by a small circle and fix the boundary of the circle You are in 2D, be aware that this means flow between two plates 1 meter deep (nothing wrong with that but its not 100% as a round "tube/pipe" Mesh, try the default physics meshing, as yours has no boundary layer and will not easy the convergence of the solver You have noslip conditions, this mans that the flow has "0" velocity at the walls, but you impose a flat inlet velocity, its better to use a parabolic velocity profile or a laminar inflow turn on the "defomration" node to see your "solid" deform Check the Reanold cell number, just to be sure you are in a good laminar regime (the case I see but it's good practice anyhow) -- Good luck Ivar
Posted: 1 decade ago 12 giu 2012, 17:38 GMT-4
Yes it can be modeled. Your model is actually deforming but very little since the pressure is much lower than Young’s modulus. The point constraint you have is problematic as Ivar described. It also does not remove all 3 rigid body modes in a 2D analysis, so add more constraints. Also for better accuracy and ease of convergence include a boundary layer mesh.
Nagi Elabbasi
Veryst Engineering
Yes it can be modeled. Your model is actually deforming but very little since the pressure is much lower than Young’s modulus. The point constraint you have is problematic as Ivar described. It also does not remove all 3 rigid body modes in a 2D analysis, so add more constraints. Also for better accuracy and ease of convergence include a boundary layer mesh. Nagi Elabbasi Veryst Engineering
